Activity › Forums › Adobe After Effects › tracking of a custom erasure?
  • tracking of a custom erasure?
    Posted by Jon Iverson on April 26, 2013 at 12:00 pm
    I have two layers, one on top of the other. The bottom layer is slightly sharper than the top layer. For this particular application, I’ve custom erased around an object in the top layer to allow the bottom layer to show through therefore giving the object a slightly sharper appearance than the rest of the scene. Now I want to track this custom erasure as the object moves, so the object continues to appear to stand out slightly in sharpness. what’s the procedure for tracking of this erased sharpness as the object moves around? I’ve been able to do two tracking points of the object as it moves, now I have to figure out how to apply this tracking to the custom erasure so the erasure moves with the tracking. I could also do this with a mask if I had to and then just track the mask. In any case, can someone direct me to a tutorial/ instructions? Thanks.
    Todd Kopriva replied 13 years, 5 months ago 4 Members · 3 Replies
  • Cassius Marques
    April 26, 2013 at 1:09 pm
    How are you erasing (masking out) the top layer?
    If the subject you’re trying to keep sharp changes shape you’ll have to do it with a mask. Otherwise just apply that track to a null and link it to whatever you’re using to matte.
    I can only advise you better if I see a screenshot of what you got there.
  • Roland R. kahlenberg
    April 26, 2013 at 11:52 pm
    If you were to use either mochaAE or mochaPro, you would track translation and export the tracking data with either mochaShape or translation data. With the latter, you will apply a mask on the tracking data (applied to a SOlid).
    It’s actually much easier to export an instance of mochaShape.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
  • Todd Kopriva
    April 27, 2013 at 4:58 pm
    Here are two videos that show rather different approaches to the same problem:
    https://www.peachpit.com/podcasts/episode.aspx?e=eb0dc392-6e0c-4028-817d-cec647ffcc29
    https://tv.adobe.com/watch/learn-by-video/adobe-after-effects-cs5-motion-tracking-and-rotoscoping/
    In the first, I show how to use the Roto Brush, and in the second I show how to use motion tracking and a mask. Both give the result of selectively applying an effect to a specific region of a layer.
    After Effects team blog
