Activity › Forums › Adobe After Effects › tracking mask
  • tracking mask
    Posted by Nufala on November 4, 2005 at 12:01 am
    hi. i have a footage layer and i need to do tracking to a mask on it. is there a way to do this not frame by frame?
    im using AE6.5
    thakns for whoever answers…
    nufar
    Chris Smith replied 20 years, 10 months ago 2 Members · 4 Replies
  • Chris Smith
    November 4, 2005 at 2:45 am
    Do a track of the image using the tracker. Apply the data to a null. Create a mask on a duplicate of the layer. Parent this layer to the null so the mask tracks with it. Then use the mask layer ontop of the original layer and set the orig layer’s track matte to alpha. Then animate the matte shape parameter to match however your mask shape needs to change.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Nufala
    November 27, 2005 at 9:58 pm
    hi. had a problem reading your mail about the alpha stuff. if u can explain again the alpha part i will thank u forever. and ever.
    starting now. thank
    nufar
  • Nufala
    starting now. thank
    nufar
  • Chris Smith
    November 28, 2005 at 5:28 am
    If you use AE you should be familiar with a layer’s ‘track matte’. A track matte allows you to take either the luminance or the alpha info of another layer and apply it to the current layer. In AE this is done by putting the layer you are borrowing from directly above the one you are applying it to. On the bottom of the two layers next to your transfer mode menu there is the track matte menu. You can set it to luma or alpha. If there is a mask on the top layer it affects the alpha of that layer. If the layer below it has it’s track matte set to alpha it will steal that masked alpha from above.
    For details on track matte, alpha channels, etc, check your manual or what I highly suggest: Read Chris and Trish Meyer’s 2 books “Creating Motion Graphics”, and “AE in Production”
    Chris Smith
