Activity › Forums › Adobe After Effects › Tracking issues when Scaling Text
  • Tracking issues when Scaling Text
    Posted by Andy Devries on February 4, 2008 at 11:43 pm
    Hello,
    I’ve found that when I animate the scale property of text with per character 3-D enabled (and probably without it enabled), my tracking becomes extremely condensed. I then have to compensate by animating the tracking. Is there a good way to avoid this? animate the character size instead of scaling?
    Thanks a lot, creativecow is a fantastic resource for me.
    andy
    Andy Devries replied 18 years, 8 months ago 2 Members · 2 Replies
  • Lisa Kwon
    February 5, 2008 at 3:40 am
    Hello:
    I’ve never seen this issue before, but my 3D light that is affecting vector layers is causing strange vertical shadow lines on its surface. (only rotating on its x axis) A friend recommended rastering all layers but unfortunately, I am too far into an HD uprez to consider this an option.
    I have tried to move the lights to reduce this but it has not solved the problem overall.
    – My shadow map is 4000 pixels and it was solving the problem but not all the time
    – And when I add another light to kill the shadow, it simply causes more issues.
    Any help would be greatly appreciated
    lisak
  • Andy Devries
    February 5, 2008 at 8:08 am
    just to clarify, when scaling text smaller, the tracking is expanded, not condensed. Essentially, the letterforms are being scaled individually instead of as a word. this creates huge gaps in between each letter when they are scaled down. HELP! thanks.
