Activity Forums DaVinci Resolve Tracking in anamorphic project.
  • Tracking in anamorphic project.
    Posted by Nick Anderson on October 7, 2011 at 7:50 am
    It’s a project with anamorphic film scan materials. All are 1828*1556 DPX from arri scanner. So I setup an anamorphic project, resolution is 1828*1556, pixel ratio is cinemascope. After bring in the dpx files, I found I also need to set the media files pixel aspect ratio to cinemascope. Then I have the right image on screen. But when I tried to track windows, the tracker just floating around, which seems resolve display images in cinemascope but still tracking in non-squeezed image, so the tracker moves double distance vertical. Am I setup the anamorphic project in a wrong way? Or it’s a knowning bug to be fixed?
    Teo Rižnar replied 14 years, 6 months ago 3 Members · 3 Replies
  • Teo Rižnar
    March 8, 2012 at 7:41 am
    Anyone got this problem solved? I am having the same issues with cinemascope footage and project. The power windows are just not useful without tracking!! I was key framing them last two days… I have a feeling of one button solution in front of my nose? Is it? where? 😉
    CHEERS!!
    Teo
    Color grade reel: https://vimeo.com/15480583
    Cofounder of https://nuframe.si postproduction
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Juan Salvo
    March 8, 2012 at 9:37 am
    Maybe not an ideal workflow, but one way to be able to do a track is to burnin the pixel aspect ratio change.
  • Teo Rižnar
    March 14, 2012 at 12:50 pm
    It is an idea of solving problem when I would finish in digital. But the project is printing back on film stock so it needs to be finished in cinemascope. I did a bit of testing and researcing and I can loose quality in going squere pix and than back in cinemascope.
    I am confused isn’t DaVinci used for a lot of big features that are shoot in cinemascope, how the “big guys” are dealing witht this? 🙂
    Cheers,
    Teo
