Activity › Forums › Apple Final Cut Pro Legacy › Tracking down an FCP Render Issue
Posted by Walter Biscardi on March 21, 2008 at 1:43 pmHi all,
I’ve posted a Memory / Render issue we’re experiencing in FCP since installing QT 7.4.1. Please let me know if you’re getting a similar experience with your systems as I spent four hours on the phone with Apple yesterday and they’re calling us back today.
https://blogs.creativecow.net/node/475
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
Erik Clig replied 18 years, 5 months ago 9 Members · 15 Replies -
Gary Alan
March 21, 2008 at 2:48 pmI also had similar problems yesterday. I was also using sequences that had subtitles that had semi-transparent black backgrounds. I did not get render error pop ups, I got crappy renderings on 30 second sequences. Flash frames, freezes, wrong dissolves.
I rebooted and and took out the black BGs and then it worked okay.
Gary
Walter Biscardi
March 21, 2008 at 3:25 pm[Gary Alan] “I also had similar problems yesterday. I was also using sequences that had subtitles that had semi-transparent black backgrounds. I did not get render error pop ups, I got crappy renderings on 30 second sequences. Flash frames, freezes, wrong dissolves.”
Thanks Gary. Are you running FCP 6.0.2 and QT 7.4.1?
Read my Blog!
Rafael Amador
March 21, 2008 at 4:21 pmHi Walter,
That reminds me the strange things that Boris CC3 used to do in preview. Thanks God render were OK.
Just to point something, could this be related with the “optical flow” caches?Mac OX 10.5.2-FC 6.02-QT 7.4.1
G5 2x2Gh 4GbRAM-BlackMagic Extreme
PMBP 17″Core2Duo 4GbRAM-AJA ioHD
JVC DTV-17″
SONY EX-1 . SONY PD170
..and always a big mess on top of the table. -
Mitch Ives
March 21, 2008 at 4:55 pmWalter,
I’m not having that exact same problem, but I am having a related issue. This is a 1 month old 8-core, so it had Leopard on it when it came. It has been upgraded to 10.5.2 and has QT 7.4.1.
The problem I have is that if I try to render out something longer, say a 28 minute sequence, it makes it around 1/2-3/4 of the way, then FCP unexpectedly quits. If I render it a third at a time, there is no problem. I can always tell when it is going to happen as the progress bar stops moving… then several minutes later, boom… FCP is gone.
This was not happening initially, so it is something recent… either QT 7.4.1 or one of the more recent patches to Pro Apps, security etc. I’ve zapped the pram, rebuilt permissions, etc.– all to no avail.
This machine has 10GBs of ram (and a Kona 3), so naturally it’s frustrating that the G5 running Tiger and 5 gb’s of ram (Kona LH) doesn’t have this issue…
Mitch Ives
Insight Productions Corp.
mitch@insightproductions.com -
Zak Mussig
March 21, 2008 at 5:30 pmWalter,
I haven’t had this exact issue, but I’ve had a lot of crashes while trying to render anything in the timeline that isn’t just video (namely Motion projects*). As a workaround for now, maybe you could build your lower 3rds in Motion and export as Animation. It adds a step along with double-rendering the same graphic, but it works whereas the “right way” doesn’t at the moment.
* – O.T. Is anyone else’s machine incapable of rendering / exporting Motion projects which include text in anything other than Motion? FCP and Compressor both hang and eventually crash on my machine. I’ve submitted a bug report ( I submit lots of Motion bug reports), but you never know if they’re going to do anything about it until an update comes out.
Zak
Shane Ross
March 21, 2008 at 5:31 pmI too have one of the new MacPros…also about a month old. OS 10.5.2, QT 7.4.1, FCP 6.0.2…basically everything updated fully. 4GB RAM, x1900XT GFX card. I haven’t had any render issues yet, but I haven’t done any heavy rendering either…still in “offline” rough cut phase. Although I have had to render a few things…but no issues at all yet.
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.LFHD.net
Read my blog! -
Rafael Amador
March 21, 2008 at 5:34 pmMitch, I have everything updated (Leopard, Qt, FC) and no one of those issues.
Are you running DiskWarrior or TechTools?
I’ve been using DiskWarrior to keep the System fit, but I just have experienced that even my eSATA HDs run much faster when the directories are clean. Just run the AJA System test and see the difference.Mac OX 10.5.2-FC 6.02-QT 7.4.1
JVC DTV-17″
Mitch Ives
March 21, 2008 at 6:08 pmShane:
I have no problems with short renders… even 10 minutes worth. It’s 28 minutes that brings it on. This sequence has a lot of green screen and I’m using a number of Livetype backgrounds on the keys, so that may be the issue. A week ago I had zero problems rendering 52 minutes of HDcam footage, but it had no keying and no LT backgrounds.
Raphael:
Not running DiskWarrior or TechTools. Perhaps I’ll give that a try.
Zak:
I’m using Livetype backgrounds, but not Motion. My issue sounds a lot like yours… the fact that some else is having issues with transparent black backgrounds, and you are experiencing issues with Motion, makes me suspect it may be related to the LT backgrounds…
Mitch Ives
Walter Biscardi
March 21, 2008 at 7:20 pm[Zak Mussig] “As a workaround for now, maybe you could build your lower 3rds in Motion and export as Animation. It adds a step along with double-rendering the same graphic, but it works whereas the “right way” doesn’t at the moment.”
Nope, that’s not something we really want to do and the issue does not just happen on Lower Thirds anyway, it even happens on dissolves and other renders.
Really crazy situation and I’m trying to find the common denominator on everyone’s system that is doing this. So far it seems to be QT 7.4.1.
Read my Blog!
Zak Mussig
March 21, 2008 at 9:10 pmFair enough… I’ve been staying away from QT 7.4.1 and sticking with 7.4, so maybe that’s why I’m not having the issue. FWIW, I also have a DeckLink HD Extreme rather than a Kona.
That said, FCP 5 (don’t want to spring for the upgrade for my occasional home use) is running just fine on my new iMac at home, and I install every update that pops up on that guy (except the occasional iApp update for the several I never use). So go figure.
Zak
