Activity Forums Adobe After Effects Expressions Tracking Child Layers – 1 Dimension
  • Tracking Child Layers – 1 Dimension
    Posted by S.j. Deluise on October 26, 2010 at 2:50 pm
    I’m using the following expression track a child layer that is parented to a null:
    c = thisComp.layer(“box”);
    c.toWorld(thisComp.layer(“box”).transform.anchorPoint);
    The expression works fine, except I only want to track the X and Z values. It’s a shadow that’s following under an object as it flies into the distance – the object casting the shadow moves up and down, but I want the shadow locked in its Y position.
    (The reason I’m not using a light to cast a shadow is that the ground is a stock video and not an actual 3D surface that accepts a real shadow, so I’m using an artificial shadow)
    S.j. Deluise replied 15 years, 10 months ago 3 Members · 4 Replies
  • Michael Szalapski
    October 27, 2010 at 1:15 pm
    Why not have a null track that child object with that expression, then have your shadow reference the null object’s position points for the x and z?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • S.j. Deluise
    October 27, 2010 at 10:19 pm
    Great suggestion and a successful one at that, thanks!
    It’d still be useful to know if there is a way to modify that original expression and cut out the middle man. It’d be one less layer. But in the meantime, the workaround is good for me.
  • Dan Ebberts
    October 27, 2010 at 11:01 pm
    This should work:
    p = c.toWorld(c.transform.anchorPoint);
    [p[0],value[1],p[2]]
    Dan
  • S.j. Deluise
    November 8, 2010 at 10:29 pm
    Works perfectly, thanks so much!
