Activity Forums Boris FX Tracking – Boris Red
  • Tracking – Boris Red
    Posted by Jeppe Svendsen on March 15, 2012 at 4:47 pm
    Hello
    What I am trying to do is create a line (spline track) and point it from a windsurfer to a text saying “Windsurfing”. I want the line to stay connected to the text in one end and to the windsurfer in the other end.
    The text stays in position and the windsurfer moves.
    I have tracked the windsurfer and want to apply the tracking data to the one end of the line only. So that the other end is anchored on the text.
    How do I do this?
    Best, Jeppe
    Peter Mcauley replied 14 years, 5 months ago 2 Members · 3 Replies
  • Peter Mcauley
    March 15, 2012 at 5:15 pm
    Hi Jeppe,
    One way to do this would be to use the Corner Pin Tracker, setting it up so that two of the points are locked to the text and two of the points are on the surfer. The pinned element is the line between the surfer and the text.
    Cheers,
    Peter.
  • Jeppe Svendsen
    March 15, 2012 at 5:33 pm
    Hey Peter
    Thanks for the answer.
    So I add the corner pin tracking filter to the spline track?
    Jeppe
  • Peter Mcauley
    March 15, 2012 at 5:51 pm
    You might want to view this tutorial:
    https://www.borisfx.com/tutorials/cornerpin.php
    It’s a little old so the UI is slightly different but the concept is the same.
    I hope this helps.
    Peter.
