Activity Forums Adobe After Effects Tracking Blur in AE
  • Tracking Blur in AE
    Posted by Tommyboy on September 12, 2007 at 8:56 pm
    Hello,
    Can someone refer me to a tutorial or give me a quick lesson in creating a tracking blur over a copyrighted poster in the background of a scene. I want the blur to be faint and have feather edges, so as to blend in with the film. Also, how would I handle someone walking in front of the poster? Create a mask over the person that would eliminate the blur when and where desired? Any help is welcome.
    Tommy
    Jimmy Brunger replied 19 years ago 5 Members · 7 Replies
  • 7 Replies
  • Brian Lynn
    September 12, 2007 at 9:11 pm
    There is good Motion Tracking tutorials on CreativeCow, check the FAQ, if you don’t find it there, try a Forums/Tutorials search under After Effects for Motion Tracking.
    As far as your subject is concerned, you will probably have to rotoscope him/her as they cross the blurred area. If you can afford it, Mocha Tracking Station is AWESOME… it will help a LOT with tracking points that go off screen, or pass behind a subject. AE’s tracking will probably handle what you need, but you will have to do a bit of manual point tracking to fix problems that occur when/if your subject covers a point being tracked…
    The tutorials found here on CC will show you the joys, and heartaches of rotoscoping/masking.
    Good luck!
  • Mike Clasby
    September 12, 2007 at 10:16 pm
    There are a couple of potions, but I like this script for roto work:
    https://del.icio.us/escruz/Rotoscope
    Put the script in you Support Folder>Scripts.
    Duplicate your layer, then draw a mask over the poster.
    Then File>Run>Script, choose rotAE.jsx.
    Select the mask, and clcik on the “Apply Tracker’, an you get a tracker setup with as many points as you had on the mask (4 I’m assuming).
    Run track on the poster (you might want to set the mask to Nonw for now), when it right… select the mask, and the Track (track 10 and clcik the Apply mask.
    Now if you apply Blur to that top layer and turn the mask to Add, feather and expand as necessary, you should be good to go.
    Alternatively (new to me):
    There is a similar script here:
    rotoTool
    converts a mask to tracker points and transforms tracking data into a mask
    https://www.nabscripts.com/Downloads/downloads_en_3.php?id=0
    The walking in front is just roto, do it with several masks, each to a body pat, like torso, head, legs, etc, then animate Mask Shape… not much fun, hopefully they walk quickly.
  • Tommyboy
    September 13, 2007 at 4:24 am
    Thanks, Guys, I’m a novice on AE… I’m good on FCP. My editor doesn’t have a lot of time, and I need to get these blurs taken care of for Sundance.
    T
  • Mike Clasby
    September 13, 2007 at 4:46 am
    You can also replace the offending poster with whatever you want. Here are some Adobe tuts:
    Keep motion in perspective
    https://studio.adobe.com/us/tips/tip.jsp?p=1&id=100241&xml=aft65cornerpin
    Using the new Motion Tracker
    https://studio.adobe.com/us/tips/tip.jsp?p=1&id=487&xml=aft6ttmotiontracker
    Tracking obscured objects in video
    https://studio.adobe.com/us/tips/tip.jsp?p=1&id=399&xml=aft6tracking
    The last one is to basically just hold down Alt/Option if you want to reposition your track points just before they go off-screen (Alt keeps the Attach point in the same relative place).
    Andrew has a lot f good tracking related stuff at his site, click his head (main page) and his link is there.
  • Todd Kopriva
    September 13, 2007 at 7:03 am
    Michele Yamazaki has a quick tutorial here for blurring out a logo using motion tracking:
    https://toolfarm.com/tutorials/motiontrack.html
  • Jimmy Brunger
    September 13, 2007 at 8:33 am
    [Dave LaRonde] “Ever do any motion tracking? This’ll get you started:
    ” target=”_blank”>https://www.creativecow.net/articles/thompson_jay/animate_still_photo/DavysFinal-cow.mov”
    I’m slightly confused in this tutew why he’s tracking a still photo? Surely you’d get the same result by parenting or pickwhipping position/anchor points?
    *Production Studio Premium CS2 / *Combustion 3 / Mocha v1
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Roland DS-5 monitors / Sony BVM-20G1E / DVS SDI Clipstation / Wacom Intuos 3 A4 / 110GB boot/80GB media/600GB RAID-0
  • Jimmy Brunger
    September 14, 2007 at 10:33 am
    Ha ha! Yeah, obviously…but surely there’s no point tracking a still when you already have control over any movement on it anyway..Just thought tracking moving footage would make more sense. I wondered whether maybe I was missing something else..
