Activity Forums Adobe After Effects Tracking an object in mocha that moves behind static objects?
  • Tracking an object in mocha that moves behind static objects?
    Posted by Bobby Yarsulik on January 8, 2014 at 10:17 pm
    I tried a little searching and didn’t really see what I was looking for.
    I have pretty much mastered the basics to mocha and can create some really cool tracking scenes.
    The one issue I have though, is lets say I’m tracking a fake sign that I have marked for tracking purposes, and it moves behind a post or pole or something. It’s a split second or so, but the track gets all wonky (of course.)
    Is there a way to mask the foreground object out so when I track the layer doesn’t get screwed up? Or at least, what is my best possible solution?
    Bobby Yarsulik replied 12 years, 8 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    January 9, 2014 at 1:33 am
    mocha’s workflow for tracking an area with foreground occlusion is as follows –
    1) track the foreground object
    2) un-check tracking (gear icon) for the foreground object (otherwise mocha will re-track it again in the next step
    3) ENSURE THAT THE FOREGROUND OBJECT/LAYER IS AT THE VERY TOP OF THE MOCHA LAYER STACK. Then track the background object
    That’s it. You can watch a related tutorial here – https://vimeo.com/8057500
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Bobby Yarsulik
    January 9, 2014 at 3:42 pm
    That was amazingly and miraculously simple! Thank you so much for the reply.
