Activity Forums Adobe After Effects Tracking a moving garbage matt.
  • Tracking a moving garbage matt.
    Posted by Murray Coulter on May 30, 2012 at 6:50 am
    Hi all,
    Here is my 2 shots both shot on a tripod without moving it. They are both panning shots and i am wondering if it s possible to matt out the windows in the internal exposed shot to show the external exposures shot underneath and have them both panning..
    I can do it fine on a static shot of both exposures but i am struggling to make it work with a panning shot.
    Any Idea’s?
    Thanks for your help.
    Murray.
    Murray Coulter replied 14 years, 3 months ago 2 Members · 2 Replies
  • Dan Fredley
    May 30, 2012 at 6:29 pm
    If I understand correctly, you can track the replacement window in MochaAE–stabilize the corner pin using MochaImport+, then track the stabilized window onto your background plate with a normal corner pin.
    Dan Fredley
  • Murray Coulter
    May 30, 2012 at 8:03 pm
    Thanks Dan, i will download the trial of Mocha and give it a go..I’ll keep you updated..
