Activity › Forums › Adobe After Effects › tracking a moving clip – why is it offset?
  • tracking a moving clip – why is it offset?
    Posted by Susan Bridge on February 21, 2008 at 11:00 pm
    I’ve got a clip of a bus which moves and I’ve done track motion to it and applied it to a new artwork layer, but when it comes to the new artwork, which is supposed to cover the existing number on the bus, it appears offset by quite a large margin. What am i doing wrong and how do i fix it? Anyone know? I’ll admit I’m a a beginner!
    Susan Bridge replied 18 years, 7 months ago 2 Members · 2 Replies
  • Mike Park
    February 22, 2008 at 12:08 am
    try this:
    1. track the motion of the bus sign you want to replace turning on position and rotation.
    2. apply the track data to a new null object layer.
    3. alt-click on the position of you replacement image and pickwip it to the position of the null object layer.
    Your new replacement layer should now track with you original footage
    Good luck
  • Susan Bridge
    February 22, 2008 at 3:58 pm
    Thankyou so much it now works a treat!
