Activity Forums Adobe After Effects Tracking a clean plate with mocha
  • Tracking a clean plate with mocha
    Posted by Josh Brine on July 30, 2012 at 1:19 am
    ok ive done this a million times but im a little bit rusty
    i have to remove a camera from a mirror,
    so i find the best frame, take a still, take it into photoshop and build a clean plate
    so far so good,
    i take the footage into mocha, and track the mirror, so far so good,
    now, What i need to do is pin the clean plate to the mirror,
    if i was to do this with a null, i would align the clean plate at the correct frame, then parent to the tracking null
    however i need to corner pin the clean plate itself, the problem is that in order to do that i need to be on the first frame of the tracking data, not the ‘aligned’ frame, if i copy the track in then the plate is offset.
    silly problem, but im missing a step in the process lol.
    anyway, if anyone gets what i mean feel free to advise
    thanks
    JOsh
    Ross Shain replied 14 years, 1 month ago 3 Members · 4 Replies
  • Dan Fredley
    July 30, 2012 at 6:32 pm
    I’m not sure I understand, but did you click “Align Surface” on the “clean plate frame” in mocha before copying and pasting to AE?
  • Ross Shain
    July 30, 2012 at 8:53 pm
    From your description, I believe your issue is in mocha, go to the frame number that you created your clean plate on. Then use the align frame function to make your surface a full frame.
    Than in AE go to the first frame of comp and past the exported mocha Corner Pin data.
    This should work, so if you are following these steps I think there is something missing.
    Best,
    Ross
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
  • Josh Brine
    July 30, 2012 at 9:15 pm
    thanks for the advice guys
    the problem isnt the clean plate itself, its essentially a copy paste problem
    if i copy the tracking info on frame one then the clean plate is not aligned,
    if i go to the frame i made for the clean plate, then copy the cornerpin, the track is off.
    its a really silly problem with a simple solution im sure, jsut cant think of it lol
  • Ross Shain
    July 30, 2012 at 9:26 pm
    Again – I believe the issue is on the frame that you are selecting “align surface. It might make the most sense to get in touch with mocha support. https://www.imagineersystems.com/contact_form
    best,
    Ross
    Ross Shain
    Imagineer Systems
