Activity Forums Zaxwerks Tracking 3d objects in 3d layer – invigorator
  • Tracking 3d objects in 3d layer – invigorator
    Posted by Jamesniblick on January 22, 2007 at 5:38 pm
    the zaxwerks literature for 4.01 claims there is a switch to allow 3d objects in Zaxwerks to be tracked with a 3d layer in an after effects composition. where is this magic switch?
    also, any idea where a list of the file formats Invigorator can import might be?
    Kurt Murphy replied 19 years, 8 months ago 2 Members · 1 Reply
  • Kurt Murphy
    January 22, 2007 at 10:13 pm
    Create either a Null layer or a Solid layer, turn on the 3D switch and animate the Null or Solid to your liking. Open up the Set that you wish to track and you’ll see a “Set X Track 3D Layer.” Assign the Null or Solid to this – it will attach itself to the Null or Solid and animate accordingly. If you use a Solid, just turn of the video eye.
    Hope this helps,
    kurt murphy
