Activity Forums Adobe After Effects Tracker2Mask: new script for tracker-assisted rotoscoping
  • Tracker2Mask: new script for tracker-assisted rotoscoping
    Posted by Mathias Möhl on December 1, 2008 at 3:26 pm
    I just finished my After Effects script Tracker2Mask, which helps to animate masks with motion trackers. In contrast to other approaches I have seen, you don’t need one track point for each mask point.
    The workflow is as follows:
    1) track a few points (something between one and four points is reasonable, even for complex mask shapes) that represent the basic movement of the object which you want to draw a mask around
    2) keyframe the mask by hand in the first and last frame
    3) use the script to predict keyframes in between (the script uses the tracker information for this prediction which is hence much better than the simple interpolation done by after effects itself)
    Step 3) can be interleaved with manual corrections which leads to a quite fast assisted rotoscoping workflow.
    I explain the tool in a video-tutorial that you can find here:
    https://www.vimeo.com/2393127
    At this page you will also find a download link; you can use the tool for free.
    Any feedback welcome.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Mathias Möhl replied 17 years, 5 months ago 2 Members · 3 Replies
  • Mathias Möhl
    December 16, 2008 at 8:33 am
    Here is a second tutorial that explains some new features (local manipulation of parts of masks):
    https://www.vimeo.com/2535683
  • Craig Wall
    March 10, 2009 at 8:10 am
    This is outstanding! What a huge productivity booster!
    Where can I download it to try it out?
    Life is full of funny particles.
  • Mathias Möhl
    March 10, 2009 at 9:02 am
    The download link is here (right below the heading)
    https://aextensions.blogspot.com/2009/02/tracker2mask.html
