Activity Forums Adobe After Effects Tracker won’t track certain scenes.
  • Tracker won’t track certain scenes.
    Posted by Arturo Sinclair on September 21, 2011 at 3:21 am
    I can track most scenes, but I have a couple of jpg sequences that refuse to track at all. THey have good contrast and obvious tracking features, they do move or shake rather fast but I have other fast scenes that track perfectly. I thought that maybe because they were jpg sequences and not movies was a problem, so I render them. Same thing. Any ideas or similar problems? I am at a loss here. Thanks for any help
    Arturo Sinclair replied 14 years, 12 months ago 3 Members · 3 Replies
  • Roland R. kahlenberg
    September 21, 2011 at 6:20 am
    Well, without looking at the footage and and your tracking setup (Search Area, Feature Region, Tracking Options), it’s hard to tell you anything useful other than to tell you that you should provide information relevant to the footage, Search Area, Feature Region etc etc etc _ 😉
    HTH
    RoRK
    Intensive AE & Mocha Training in Asia.
  • Ben G unguren
    September 21, 2011 at 3:24 pm
    Increase the search area — the large box around the tracker point. That defines the area that AE will search in the next frame, so if there’s a lot of shaking going on, you’ll need to have a large enough box to account for that shake. Note that the larger the box, the more image there is to process, and thus the longer it takes….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Arturo Sinclair
    September 26, 2011 at 9:56 pm
    Thank you. It did improve by increasing the search area but it would still get lost at points where there is nothing apparently different.
    Here is one frame: https://www.flickr.com/photos/51035746019@N01/6186412325/in/photostream/
    Another frame at it’s most blurred: https://www.flickr.com/photos/51035746019@N01/6186936020/in/photostream/
    As you can see the scene is simple, a high contrast statue against a blue sky, that is all. You would think it is the easiest track of all. There is some movement but not excessive.
