Activity Forums Adobe After Effects Tracker Trouble
  • Tracker Trouble
    Posted by Donald Mitchell on April 20, 2012 at 7:02 pm
    I’m trying to track a circle in a piece of footage that’s about 15 pixels in diameter. It’s got very good contrast. I set the tracking cross to the centre of the circle and adjust the 2 boxes to just cover the circle. When I track though, the tracker drifts slightly and I have to adjust gaziliions of points.
    I find the tracker quite good with finer detail, but how can I get it to follow this circle properly? Is there a plug-in tracker that might do it better? I’d like a tracker that would track the circle shape, and centre the tracking point in the circle.
    Any advice much appreciated!
    Donald Mitchell replied 14 years, 5 months ago 2 Members · 2 Replies
  • Benjamin Ausmith
    April 20, 2012 at 7:41 pm
    Your second circle is where After Effects looks for your track, so it doesn’t have to scan the entire image every frame. Make your second box bigger, so After Effects has a larger search radius frame-to-frame. That should do it.
    Benjamin Ausmith
    Post-Production Assistant
    Monadnock Media, inc.
  • Donald Mitchell
    April 20, 2012 at 8:49 pm
    ok will try enlarging the second box. But how will the tracker stay in the middle of my white circle? Is that controlled by the inner box?
