Activity › Forums › DaVinci Resolve › Tracker: Set point feature not working ?
Posted by Gabriele Turchi on February 13, 2011 at 5:09 pmHaving a power window
On the tracker module
Clicking enter interactive
Clicking delete points
Having the cursor on the image
By clicking “set point” should drop a track point ,and as many as you want on the strategic points you want for the tracker …But when i click “set point” it does not drop a point …
Seems that only the “add points ” (multiple ) worksIs it a bug ?
thanks
g
Gabriele Turchi replied 15 years, 7 months ago 2 Members · 9 Replies -
Gabriele Turchi
February 14, 2011 at 3:38 amhi warren ,
yes i saw that on your FXPHD course when you tracked that guy eyes …i think might be a bug …what you suggest is a good turnaround …that actually you just showed on Vimeo !!
PS:Thanks so much for the vimeo tips … i hope you will start soon a serious online thing …
g
Dwaine Maggart
February 17, 2011 at 2:34 amThere does appear to be an issue here. Set Point is working for me, but there is an offset from where the cursor is to where the point gets placed. If the cursor is in the center of the image, it works. As you move away from center, the point placement offset grows. It also appears I can’t make a point very near an edge, even if I try to compensate for the offset.
Problem noted.
Can you please verify that Set Point can work for you, if the cursor is near center screen?
Dwaine Maggart
Blackmagic Design DaVinci Support -
Gabriele Turchi
February 17, 2011 at 3:07 ami noticed that the point is actually set with a huge offset , but also i noticed that if i click track forward it actually reselect many many points automatically …
g
Dwaine Maggart
February 17, 2011 at 7:05 pmCan you please test that if you put the cursor in the center of the image, how big, if any, the offset is? If you have a large offset with the cursor in the center, could you tell me what Timeline Resolution you are in, and what your source material resolution is? Are you doing anything from default on the input or output formatting?
Dwaine Maggart
Gabriele Turchi
February 17, 2011 at 8:42 pmhi dwaine,
i installed 7.1.1 and i did further tests:now i have 2 problems about this :
it seems that i have no more shift (being anywhere in teh screen) but sometimes the point does not get set ,when this happen moving the cursour a bit than it does set the point ….
But the main problem is that after i set the point , being on interactive , if i click track forwared , it does not track , it say “no live features to track …”
i tried on Red 2K footage (HD project) and using HD dpx (on HD project)….
so anything i do being on the interacting mode , (even just deleting the deafult assigned points) than the tracker does not track forward…
g
Dwaine Maggart
February 18, 2011 at 12:05 amThanks Warren. That’s basically what I see as well. Just wanted to confirm.
Dwaine Maggart
Gabriele Turchi
February 18, 2011 at 3:38 amhi dwaine ,
why i have a different behavior ?
in my resolve after i set the points (that actually it place it on the right place (aside the fact that sometimes it does not place them )… if i click track forward i get the message “””no live features to track”””
any idea?
g
Gabriele Turchi
February 18, 2011 at 4:59 amhi warren,
today i tried on 7.1.1 having a master session timeline (HD project ) with 1 R3D shot and 1 DPX shot… i got the same message on both ,and with any kind of shape …PS:in “”Non interactive “” it work fine …
g
Gabriele Turchi
February 19, 2011 at 2:24 amdoe anyone else have the same problem i have being on interactive mode ?
getting the message “no live features to track ” ?
it’s quite a problem for me ….
thanks
g
