Activity › Forums › Adobe After Effects › tracker control problem
  • tracker control problem
    Posted by Albertoloco on October 23, 2007 at 1:53 am
    Hi, I have a problem with tracker control. I don’t see “Tracker Control” under “windows”, and when I right click on the video, the “Tracker control” button is greyed out. Anyone can help? Thanks alot
    Albertoloco replied 18 years, 11 months ago 3 Members · 3 Replies
  • Peter O’connell
    October 23, 2007 at 4:13 am
    You may have standard, not pro.
    Pete O’Connell
  • Rob Webster
    October 23, 2007 at 4:55 am
    If you have pro, try re-installing. I had this problem, too, and couldn’t find a reference to it anywhere. At boot-up, a warning would tell me “tracker control palette is missing”, and I’d have the same symptoms as you. A re-install seemed to correct it for me.
  • Albertoloco
    October 23, 2007 at 11:46 am
    Thanks alot, i will try to reinstall it and see what happpens.
