Activity Forums Adobe Premiere Pro Track Select Tool – Select clips to the left
  • Track Select Tool – Select clips to the left
    Posted by Sean Murphy on July 16, 2013 at 9:12 pm
    Hello all,
    I am a new convert from FCP7 to Premiere Pro CC. I have used the track select tool in FCP and still use it in Premiere, however, in FCP you could select all the clips to either the left or right. Is that feature available in Premiere? I have been successful in selecting a single track or all tracks to the right but not the left.
    Thanks for your help,
    Sean
    Matt Orfalea replied 12 years, 5 months ago 3 Members · 2 Replies
  • Dax Roggio
    August 9, 2013 at 1:24 am
    I found your post because I have the same question. In FCP, you could press T four times to select all tracks backward (to the left). It doesn’t appear that Premiere has that ability, which is unfortunate.
  • Matt Orfalea
    April 9, 2014 at 4:44 am
    I would also like to select clips to the left with the track tool as in FCP. If anybody has figured a solution please share!
    Thanks in advance!
    Matt
    https://www.youtube.com/orf
