Activity Forums Maxon Cinema 4D Track Randomizer Object?
  • Adam Trachtenberg
    June 10, 2012 at 4:21 am
    Give your cloner an external compositing tag and check the “children” box. Then check the “3D data” option in the render>save>compositing section and Cinema will export a null for each clone (or a solid if you choose that option).
  • Allen Joaquin
    June 11, 2012 at 2:48 pm
    Amh, no, i din’t got any null object for the pieces i only got the cameras.
    Also i’m using a randomizer not a cloner.
  • Adam Trachtenberg
    June 11, 2012 at 4:04 pm
    Sorry, I missed your screen shots. So instead of putting the external compositing tag on a cloner, as I said, put it on the Fracture Object and check the “children” box in the tag.
    Then, in the compositing export render options, check the “Include 3D data” box.
    That should give you the nulls you seek.
