Activity › Forums › Apple Motion › Track Point something
  • Track Point something
    Posted by Chih Fong pan on December 9, 2009 at 11:00 am
    How Can I apply Shape_Track Point behavior to track Paint Stroke with Shape_Write On behavior (arrow head) ? or another way got it ?
    Mark Spencer replied 16 years, 9 months ago 4 Members · 8 Replies
  • 8 Replies
  • Stephen Smith
    December 9, 2009 at 3:37 pm
    If you want to just track the arrow head I would use the Match Move Behavior in the Motion Tracking Behaviors section.
    Utah Video Productions
    Check out my Motion Tutorials
  • Mark Spencer
    December 9, 2009 at 3:40 pm
    I think you are going to have to export your arrow animation as a movie, bring it back in, and then analyze the motion of the movie with a tracker on the arrow head – then track the point of your balloon shape to the arrowhead.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Mark Spencer
    December 9, 2009 at 3:42 pm
    Did you get that to work, Stephen? I don’t see how you can match move a control point of a shape to the movement of the arrowhead unless you first bake the arrow animation as a movie.
    Mark Spencer
  • Stephen Smith
    December 9, 2009 at 4:16 pm
    Good point!
  • Chih Fong pan
    December 10, 2009 at 1:47 pm
    Thanks everybody help, I Know How to do that (Export and Analyze). But have another behavior or tricks and tips do that?
  • Andy Neil
    December 12, 2009 at 7:28 pm
    Here’s what I’d do:
    Create a null object. Basically a small shape like a square or circle. Add the Motion Path behavior to it. Change the path shape to geometry and add your paint stroke or line as the path shape. This will force the null to follow the same path as the write on to your arrow.
    Then apply the track points behavior to your text bubble and use the null shape as the source. Make sure to turn off the null so it doesn’t appear in your scene.
    As you may or may not know, you can limit which points in your text bubble are affected by the track points behavior. By default, they all are, but all you have to do to limit this is (with the behavior selected) CMD+click on the points you don’t want to move. They will turn blue in the canvas.
    Here is a link to a sample project in case my explanation wasn’t clear enough.
    423_trackpointsbehavior.motn.zip
    Hope this helps.
    Andy
  • Chih Fong pan
    December 13, 2009 at 2:56 pm
    Great!!!!!
    So cool, that is new concept for me! thanks a lot! show me a new world from behavior!
    Apple Certified Trainer – Final Cut Pro 7 Level One
  • Mark Spencer
    December 13, 2009 at 6:52 pm
    Outstanding solution, Andy. One thing to add – you need to make sure that the Motion Path behavior has the same location and duration as the Write-On behavior for this to work – but if you do, it works perfectly. Very nice.
    Mark Spencer
