Activity › Forums › RE:Vision Effects › Track Point
  • Track Point
    Posted by Shinji3c on September 3, 2007 at 7:27 pm
    Hi
    Thanks for great great products.
    I am studying Twixtor and found these settings in Pro version. “Track point”
    What are we exactly to track? I saw some examples from your tutorials and sample files but I’m still kinda lost and confused.
    Thank you!
    Peter Litwinowicz replied 19 years ago 3 Members · 3 Replies
  • Pierre Jasmin
    September 4, 2007 at 5:48 am
    In what application are you running
    See the sample projects on Twixtor Support Page on the website
    The tracking points serve the same purpose as the Splines, basically help Twixtor in certain circumstances (when it does not work well). Imagine something crosses the screen in 5 frames, it’s way out of reach of the internal tracking, so if you animate points that follow the image content for these 5 frames, then Twixtor should work much better…
    In AE for example you can’t attach a tracker to a roto mask control point, so if you track some points, it will guide Twixtor to start somewhere internally. In Combustion since you can attach a tracker to a roto mask shape then the points are not necessarily useful. In other applications, there is no way for us to support roto masks (like there is no such things in FCP), so you can always use individual points.
    Pierre
  • Shinji3c
    September 4, 2007 at 7:48 am
    THanks for the reply
    I’m using it on AE
    So, you would have to draw splines or provide track point to the twixtor but how do I figure what to give it?
    Do I simply draw splines or track point at the following motion and it tells twixtor that that is the following motion after this one so dont go any farther?
    If that’s the concept and If I’m right, I can breathe easy for now.
    Thank you
  • Peter Litwinowicz
    September 5, 2007 at 3:15 pm
    Yes, that’s the idea. Besides our sample projects, did you see the manual that was installed with Twixtor upon installation. THere is a whole section on points and splines that describe how to use them to guide the tracking when it “goes bad”.
    Pete
