Activity › Forums › VEGAS Pro › track motion problem
  • track motion problem
    Posted by Thomas Quinn on November 18, 2005 at 9:54 am
    I am using track motion to have four screens on one background I shoot in PAL I have rendered to mpeg2 the problem is when played back on the computer screen or on a a DVD on a TV any shot with a pan or any movement has a desperate jagged or vertical wave look which spoils the shot is there another way to do picture in picture in Vegas 6 or how do I fix this using track motion.
    Thomas
    Chris Young replied 20 years, 10 months ago 3 Members · 2 Replies
  • Edward Troxel
    November 18, 2005 at 2:52 pm
    Did you try using “Reduce Interlace Flicker”? You might also see if moving the PIP up or down one scanline makes a difference.
    Edward Troxel
    JETDV Scripts
  • Chris Young
    November 20, 2005 at 3:28 pm
    Thomas ~
    This is a problem I have seen crop up every now and again with track motion and even in pan and crop with resize. Working here in PAL also. I have tried every manner of options under ‘properties’ for the clips in questions and no luck I am afraid. All the resample options plus reduce interlace flicker etc and I can’t get rid of the problem. I have also tried blend fields and interpolate in the project properties all to no avail. I have also seen this problem with upper field clips rendered in a lower field project so just check that your field dominance is lower field on the original ingested clips. I notice that this problem when it raise its ugly head is far worse when the clips involved have a lot of fast motion and panning etc, like motor sports which we do a lot of. If anyone has the answer I would love to know what it is.
    Chris Young
    CYV Productions
    Sydney
