Activity Forums VEGAS Pro Track motion problem
  • Track motion problem
    Posted by Dylan Evans on June 22, 2011 at 8:18 pm
    Hi, I’m having a problem with launching track motion in Vegas. When I either access it through tols or click the button on a video track, a blue bar (which appears to be the ‘top bar’ with minimise, restore etc. on it, not sure of the proper name)appears but then moves towards the bottom of the screen, only to disappear again.
    I’m very confused by this as I cannot think of a reason or solution, any help is much appreciated.
    I have attempted to attach a video of the problem to better illustrate it, however the ‘phantom window’ doesn’t show on my screen capture (I’m using Camstudio)
    thanks
    Dylan Evans replied 15 years, 2 months ago 2 Members · 2 Replies
  • Matt Crowley
    June 23, 2011 at 8:18 pm
    You may have been hit with a glitch where it’s possible to move the track motion window (and other dockable windows) underneath the Windows taskbar… and then you can’t reach it to get it back.
    The solution is to set the taskbar to autohide, so that it collapses to a thin bar at the bottom of your screen. Then you should be able to see the top edge of the track motion window and drag it back up where it belongs.
  • Dylan Evans
    June 24, 2011 at 2:23 pm
    that’s exactly what happened! I actually uninstalled and reinstalled to try and fix it but then the same happened (I realised what it was) and I did what you’ve said to fix it. It’s annoying that only after I reinstalled did I realise what it was but it’s fine now!
    Thanks for the reply, you were dead on (even if I beat you to it!
