Track Motion / Pan Crop question
I’ve just started editing video of friend’s band. Used three cameras combined with multi-track audio recorded by another friend. Band would like a video wall with the remaining quarter used for stills of art work they have done. I’m at a beginners level. Appeciate any critique of my work flow, especially concerning my use of Track Motion and Pan Crop.
Here’s my work flow!
-Drop all video on time line.(bass, guitar and drums).
-Drop good audio(multitrack rendered down to stereo)on timeline.
-Sync ’em all up.(I’d made three hand claps at the start of each set)
-Delete camera audio tracks.
-Trim clips, then butt them all up to start of timelineSo far so good, until…
-Use Track Motion to move each track to their respective corners.
-Then use Pan Crop to properly frame subjects(pull them into safe areas and make aesthetically pleasing).From what I’ve read on forums I think Track Motion will reduce frame resolution to quarter then I’d be panning in on that. Not good. Yikes. Forgot i have to do color correction somewhere in there. I assume video effects are best used on full resolution frame.
Ok, questions…
-is there a way to move tracks to the four corners and pan in on each frame without Track Motion?-if I just use Pan Crop will video effects be on the full resolution frame or just the panned cropped rez.
Hope I’ve used the right terminology.
Thanks, Kevin
