Activity Forums VEGAS Pro Track Motion Keyframes keep changing? (Vegas Pro 11)
  • Track Motion Keyframes keep changing? (Vegas Pro 11)
    Posted by Roy Gregorio on April 13, 2012 at 6:21 am
    I’m trying to manually stabilize about 24 frames of very slightly unstable footage. I go through each frame one by one and adjust the X and Y positions to match as it progresses. By the time I finish, it looks perfect and ready for rendering. When I render, everything looks good!
    The problem is when I save and exit Vegas and reload the project. When I play back those 24 frames, it still has the adjusted keyframes on there, but it seems to be way off. The X and Y adjustments I made don’t align with the shakiness of the footage that I had previously and painstainkingly adjusted. So I have to adjust all 24 frames again.
    Also, when I change from previewing in Best to Preview, the keyframe adjustments also lose alignment. Kind of frustrating.
    I’ve repeated this about 6 times until I finally decided to sign up on this forum and ask for help.
    Roy Gregorio replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
