Activity › Forums › VEGAS Pro › “Track Motion” except not the whole track (?)
  • “Track Motion” except not the whole track (?)
    Posted by Kelly Griffin on June 8, 2011 at 12:46 am
    I’ve got a 30-sec. spot with several graphic overlays needing various positionings and dropshadows with various values. The only place I see to achieve that is on “Track Motion”, but, with track motion affecting the whole track, I don’t see a way around having to add a track every time I want to add a graphic element, just to add a position and a shadow on it and have it just sit there for its duration. I know about keyframing, but I can’t imagine that being the “elegant solution”.
    Is there an “Event Motion” (my term) that’s an equivalent to “Track Motion” that lets you do these things to individual events on the same track without assigning universal attributes/keyframes to anything that occupies that track?
    Thank you!
    –Kelly
    Kelly Griffin replied 15 years, 3 months ago 3 Members · 10 Replies
  • 10 Replies
  • John Rofrano
    June 8, 2011 at 1:06 am
    [Kelly Griffin] ” I know about keyframing, but I can’t imagine that being the “elegant solution”.”
    Actually keyframe is the solution and it’s very elegant. You just create a keyframe and the beginning of each event on the track to position it however you want.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Kujbida
    June 8, 2011 at 1:16 am
    [Kelly Griffin] “I’ve got a 30-sec. spot with several graphic overlays needing various positionings and dropshadows with various values”
    I’d create them in Photoshop, save them as PNG (handy if you need an alpha channel) and drop them on the timeline at the appropriate locations.
    That way, there’s no need for Track Motion or keyframes.
  • Kelly Griffin
    Yikes… okay, I’ll try to wrap my head around that.
    Thanks.
    –Kelly
  • Kelly Griffin
    June 8, 2011 at 1:24 am
    Mike: Well, I thought about that, but depending on what the graphics fall on top of makes the determination of how dark to make my shadows. I was hoping to keep things flexible in that regard.
    I’m going to try to get used to John’s suggestion, but I’m nervous about how easy it seems like it would be to screw something up with keyframes all over the place with just positioning static elements.
  • Mike Kujbida
    June 8, 2011 at 2:00 am
    Kelly, here’s something else to try.
    Go to https://sony.vegas.1.free.fr/ and grab the free “Open In Graphic Editor” script.
    Unzip it and follow the installation instructions.
    Once installed, this script allows you to click on an image, click the toolbar icon and have it open in Photoshop (or whatever graphics program you designate to the task).
    Once it opens in Photoshop, it automatically saves a copy as a new take over top of the image you just clicked on.
    Make your changes, re-save the image, exit Photoshop, go back to Vegas and continue working.
    In your project, I’d create the graphics with a light drop shadow and save them as PSD files.
    That way, when you run this script, the original file with all its layers opens up allowing you to darken the drop shadow as needed.
    p.s. I use a few of the scripts on this site as they are very useful but the one I mentioned is my favourite.
  • Kelly Griffin
    June 8, 2011 at 2:05 am
    Thanks Mike!
    I’m betting my version of Photoshop won’t like it, though…!
    –Kelly
  • Mike Kujbida
    June 8, 2011 at 2:07 am
    Kelly, I still have Photoshop 7 on my computer and it works for me.
    I just got CS5 at work but haven’t had the time to try it out.
    Based on what I’ve read on various forums, it shouldn’t be a problem.
    Just make sure to follow the installation instructions and you should be fine.
  • Kelly Griffin
    June 8, 2011 at 3:54 am
    A man after my own heart. I’m still using Photoshop 6 (I’ve been boycotting “upgrades”).
  • John Rofrano
    June 8, 2011 at 2:15 pm
    [Kelly Griffin] “I’m going to try to get used to John’s suggestion, but I’m nervous about how easy it seems like it would be to screw something up with keyframes all over the place with just positioning static elements.”
    Keyframes are just a marker in time where you want a change to happen. Kind of like appointments on your calendar. You can change the keyframes to be HOLD keyframes by right-clicking on them and changing their type. Then those parameters will hold until another keyframe is encountered.
    You might want to watch Sony’s free webinar replay:
    Mastering Keyframing Techniques
    You could always use multiple tracks if keyframes seem to complicated.
    ~jr
  • Kelly Griffin
    June 8, 2011 at 8:40 pm
    Thanks, John. No, it’s probably fine, just another instance where I have to change my thinking from what I’ve been used to for so long…
    –Old Dog, New Tricks
