Activity Forums Adobe After Effects Track Matte – White to Transparent
  • Track Matte – White to Transparent
    Posted by Adam Lewen on August 25, 2008 at 10:37 am
    Hi there
    I just achieved something i wanted, but didn’t save…
    Now I am having trouble redoing it.
    Thing is, it took me a few sec to do it in the first place…
    To simplify things
    Lets say I have 3 layers
    TOP- White squares
    MID- Adjustment Layer that effects the BOT
    BOT- BG LAYER
    All I want to get is to convert the TOP (those white squares) to transparent (that I will see NOTHING, not even the BG Layer, behind).
    I believe I did so with a Track Matte.
    Does anyone have an idea on what am I doing wrong here?
    I do not want to Key out the White color…
    Thanks for any input
    Adam
    Adam Lewen replied 18 years ago 2 Members · 4 Replies
  • Jerry Renes
    August 25, 2008 at 12:31 pm
    So the only thing you want to see is the layer with the white squares? OR do you just want to see the background layer on the places where white squares are?
    Either way, maybe it helps to say that when you press the toggle Switches / Modes button (in the middle, below the timeline) You get the Mode / Trackmatte dropdownboxes. You might want to try these. Try to set the background’s trackmatte to the Top layer.
    Good luck.
    Jerry
  • Adam Lewen
    August 25, 2008 at 12:42 pm
    What I want to see eventually is the BG layer with “holes” of transparency where the white squares were. (the transparent checkered ‘nothing’ behind…)
    Thanks for reading
  • Jerry Renes
    August 25, 2008 at 2:44 pm
    Ok, then place the TOP layer above the BG layer, press the toggle switches button and in the dropdown box select Alpha Inverted matte [TOP layer] This will give you the desired look.
    Good Luck!
  • Adam Lewen
    August 26, 2008 at 10:36 am
    Thanks! Did a precomp to all BUT the Top layer and inverted based on the top layer’s boxes…
    Worked.
