Activity › Forums › Adobe After Effects › track matte of a track matte?
Posted by Tom Gomez on June 14, 2013 at 5:24 pmGreetings Earthlings,
I’d like to do an alpha matte of an alpha matte without precomping…
I can’t precomp because of crazy expressions, etc.
Possible?
thanks!
Tom
YOU can help save TimeSpace. Join the Chronos Protectorate!Tom Gomez replied 13 years, 3 months ago 4 Members · 7 Replies -
Darby Edelen
June 14, 2013 at 6:02 pmSomething like that may be possible but it depends somewhat on the specifics of your situation. Can you describe what it is you’re trying to achieve? What kind of assets are you using (footage, stills, 3D layers, shape layers, etc)?
In general I’d recommend the Set Matte effect but the implementation varies depending on the specifics.
Darby Edelen
Tom Gomez
June 14, 2013 at 6:53 pmFor all intents and purposes, let’s say it three shape layers.
Naturally the one on top is the alpha matte for the second.
Why can’t the third assign the track-matted second as it’s track matte? That would be so nice if it did…
There are lots of ways to do the masking I’m after, but because of crazily nested and expressioned elements, they are all a pain! 🙂
But I’ll mess with Set Matte. I’ve never really used that. THANKS DARBY!
I would be great if someone could tell me why AE doesn’t let you do a stacked series of mattes though.
YOU can help save TimeSpace. Join the Chronos Protectorate!https://www.95ers.com
https://www.SpaceAceMedia.com -
Darby Edelen
June 14, 2013 at 11:59 pmSet Matte is a perfect candidate for Shape Layers or any other layers with the continuously rasterize/collapse transformations switch enabled.
Darby Edelen
Walter Soyka
June 15, 2013 at 12:17 am[Tom Durham] “I would be great if someone could tell me why AE doesn’t let you do a stacked series of mattes though.”
My guess is that it presents a recursion problem: you have to render the matte layer before rendering the layer it cuts. This is an inversion of the standard rendering order, and creating a stack of these could require an awful lot of out-of-order rendering, so it may not fit neatly into the internal rendering pipeline.
That said — this shouldn’t be impossible and stacked mattes would make a fantastic feature request [link].
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Walter Soyka
June 15, 2013 at 1:05 am[Tom Durham] “I can’t precomp because of crazy expressions, etc.”
I should note that you can use expressions across comps. You can even pickwhip from one to another if you tear off the tabs of the timeline windows so you can see more than one timeline at the same time.
Walter Soyka
Roland R. kahlenberg
June 15, 2013 at 4:15 amI’m not sure what you’re trying to achieve visually BUT if you set the top-most layer’s Blending Mode to Stencil Alpha, you will be able to cut into the alpha matte construct of the lower two layers.
Of course there could be more than two layers below the Stencil Alpha Layer AND of course you can have multiple layers with the Stencil Alpha Blending Effect. Incidentally, the latter is another option for your specific case of three layers with two layers acting as mattes.
HTH
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE -
Tom Gomez
June 17, 2013 at 8:33 pmAwesome! Thanks Roland I’ll give it a shot!
