Activity Forums Adobe Premiere Pro Track matte changes proportion between different work stations.
  • Track matte changes proportion between different work stations.
    Posted by Marshall Eide on March 7, 2022 at 1:09 am
    Hi there!
    I’m using Premiere Pro’s Track Matte Key effect on a nested sequence using a video layer above it as a Luma matte. I wanted to avoid using because mine always turn out imperfect. After much trial and error, I made a black 1280×720 (same as sequence) background with a rounded white box on the left side of the screen. I saved it as a ‘.png’. I thought it wouldn’t need any adjustments, because it’s in the perfect spot. However, it doesn’t even show until I scale it down.
    So I go to an older version I made that’s not that resolution, but just the box; and instead conformed with Premiere’s position properties. Looks great! Then I went to work on it at another work station and, it’s super tiny or halfway off the program monitor. What’s going on? Is Track Matte Key obsolete?
    Marshall Eide replied 4 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
