Activity › Forums › Adobe After Effects › Track line by it’s two ends (look like a spiderweb)
Posted by Christina Labelle on April 29, 2009 at 2:21 pmHi!
I have a problem tracking a line in After effects… It seems simple, but my brain just stopped thinking. I want to track this line by it’s two ends so it looks like a spiderweb. I tried the puppet tool pins, tried some expressions with effects, tried with masks and now, my nose’s bleeding because i’m thinking too much… Please, someone, HELP ME!!!
ThanksChristina
Philippe Lessard replied 17 years, 4 months ago 4 Members · 8 Replies -
David Bogie
April 29, 2009 at 3:24 pmChristine, how does one go from “tracking a line” to a spiderweb? I have no idea what you’re seeing in your head so wipe your nose and try rephrasing the question. (You’re being issued a ticket by the Grammar Police: it’s is the contraction, not the possessive)
bogiesan
Christina Labelle
April 29, 2009 at 3:39 pmThank you for correcting my english, i’m french so i try to do my best. I’m trying to make something like that:
https://www.quayola.com path to nature.Thanks
Christina
(Geek and Proud to be a french Canadian) -
Kevin Camp
April 29, 2009 at 6:37 pmyou may be looking for the beam effect.
it will connect 2 points with a line. those 2 beam points can be attached (via the position expression pickwhip) to nulls (or other layers) that could be tracking points on a clip if that is what you are looking for.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Christina Labelle
April 29, 2009 at 6:48 pmThanks Kevin! That was so simple…
Christina
David Bogie
April 29, 2009 at 8:59 pmOh. That’s different. Glad we got that cleared up. So all you want to do is connect the dots?
Try Glue Gun (needs a mask or other path) and Lightning, too.
Do you have any other plug packages? Delerium has a great laser effect, similar to beam, but more stuff to tweak.bogiesan
Philippe Lessard
April 30, 2009 at 4:03 pmBonjour Christina,
Si tu veux tracker un detail dans ton video pour ensuite attacher les point d’ancrage de l’effet beam, tu dois utiliser le tracker de AE, si tu as CS4 je te conseil d’utiliser mocha qui vient avec CS4, il est beaucoup plus efficace, il y a des tutos sur internet.
Si ça peu t’aider.Philippe Lessard
Post-prod Tech
Alt Productions
Mtl,Qc,Can -
Christina Labelle
May 1, 2009 at 1:54 amOui, merci, j’ai eu ce que je voulais simplement avec le beam effect. C’est drôle ça, tu dois connaître Matt Dumont, stagiaire chez Alt:P
Christina
