Activity › Forums › Adobe After Effects › Track Camera Disabled on Clip from Premiere CS6?
Teo Karakolev replied 12 years, 8 months ago 4 Members · 12 Replies
Roland R. kahlenberg
August 31, 2012 at 12:09 amIt’s definitely a limitation of the Camera Tracker – it refuses to accept changes in transformation within the same comp where the 3D Camera Tracker is applied. I think it’s a Feature Request as much as it is a Bug.
Cheers
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
Teo Karakolev
January 8, 2014 at 10:41 pmHere is my solution:
Select the Pre Comp, go to Effects>3D Camera Tracker. Apply it to the Pre Comp. In this case it will probably give you a warning sign and a red banner saying it can’t 3D Track a Collapse Transformation layer. So, on the left of your Pre Comp layer there is the Collapse Transformation button (the 2nd one). Just turn it off. You are all set.
The reason this function is turned on probably is because you are working with offline sequence in PP, or your sequence is different from the footage aspect ration and resolution that you are using. For example, I work with RED 5k (5160×2160) in Premiere Pro in an offline 720p sequence with the “Adjust to Frame Size” function turned on on every clip. The Collapse Transformation function in AE is basically the “Adjust to Frame Size”. So, if I decide to export in any of the softwares from the Offline 720P sequence to the 5K, it will Rasterize accordingly with me not needing to create a new 5k comp in any of the softwares (or at least this is how I’ve been working and seems to be working right). However, let’s say I want to Warp Stabilize in PP, It won’t work, because the footage doesn’t match the sequence. So, you nest it in the offline sequence and you’re all set. Warp Stabilizer and Track Camera share almost identical way of analysis the footage.
It’s a messy explanation, but I hope you get it.
Best,
Teo
