Track and pan with a projectile through multiple video files.
Hi, I have a bit of an odd question. Is there a way to track an object or pan over multiple clips in After Effects?
I am capturing a projectile with four different highspeed cameras triggered in sync, and i want to put those next to each other so that I can show the continous flight path of the projectile over the four different videos. Is there a way to track this so I can pan the videofiles past a full HD window to achieve a similar look like in the video below:
https://www.youtube.com/watch?v=uN1TZ4Yr0nc
The video is taken with Specialised Imaging’s Tracker system, but don’t have access to such a system and I was hoping to solve it as described above.
Fredrik
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
