Activity › Forums › Zaxwerks › track 3d layer
  • track 3d layer
    Posted by Susan Cox on March 10, 2010 at 5:43 am
    I have a globe that I want to spin, I created a solid and made it 3d and rotated the y axis. I then added a camera
    In my invigator layer I chose the spinning solid and I’m using the comp camera.
    The globe does not spin, am I missing a step?
    Thnaks,
    Susan
    Edward Wu replied 16 years, 6 months ago 3 Members · 8 Replies
  • 8 Replies
  • Serge Hamad
    March 10, 2010 at 5:21 pm
    Hi Susan,
    There are two thinks that come to my mind:
    1- You still didn’t apply a texture to your sphere. It’s hard to see any changes when your globe has a simple plain color.
    2- You didn’t refresh your Invigorator layer after linking it to the 3D layer. You need to click the Draft/Best quality switch twice
    (after each animation) to do so.
    Does this help?
    Salut.
    Serge
    NEW! InvigoMany-Media available here: https://www.nyc-visual.com
    Invigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
  • Susan Cox
    March 10, 2010 at 5:46 pm
    Thanks Serge,
    I actually did do both, but it’s still not working, I’m not sure what the problem is.
    cheers,
    Susab
  • Serge Hamad
    March 10, 2010 at 6:06 pm
    Feel free to send me your project (without media files)
    (serge at nyc-visual dot com)
    Salut.
    Serge
  • Susan Cox
    March 10, 2010 at 7:21 pm
    I would love it if you could look at this for me.
    I’m using 3d invigorator pro 4.51 using ae cs 3.
    Cheers,
    Susan
  • Serge Hamad
    March 10, 2010 at 7:39 pm
    Susan, Your globe was assigned to set # 5 and your tracking layer to Set # 1.
    Just reassign your object in the Set-Up window to set # 1 and you are ready to go!
    Best.
    Serge
    NEW! InvigoMany-Media is available here: https://www.nyc-visual.com
  • Susan Cox
    March 10, 2010 at 7:48 pm
    How crazy,
    I only have the object, and I assumed that it was set one, how do I know what set the object is assigned to.
    and thank you, I thought I was losing my mind.
    Susan
  • Serge Hamad
    March 10, 2010 at 7:56 pm
    When you import or create an object, Invigorator automatically assigns it to set1. Unless you change the prefs in the User Prefs menu.
    To know in what set your object resides, just select it in the Set-Up window and you will see a set # right to the object listing menu.
    Salut 😉
    Serge
  • Edward Wu
    March 10, 2010 at 7:58 pm
    Hi Susan,
    By default, new objects that are created are placed into Set 1. However, you can assign objects to different Sets by going into Object Mode, and going into the “Set” drop down menu. The objects that you’ve selected will be assigned to the Set number that you selected in the drop down menu.
    Best,
    Edward
