Activity Forums Maxon Cinema 4D Tracer -> two splines (rails) for Sweep NURBS ?
  • Tracer -> two splines (rails) for Sweep NURBS ?
    Posted by Sergei Sokolov on June 6, 2010 at 8:44 am
    Hi!
    Inspired by Greyscalegorilla tutorial on the Tracer object in Cinema 4D, I tryed to create a bit more complex effect of [toilet] paper rolls with trails.
    Which doesn’t work with a single spline generated for each single roll.
    How can I get two splines to Sweep along with correct rotation of the “paper” ?
    Tryed cloning a two-point Spline and switching on the Trace Vertices option in Cloner – it does make two splines but then the SweepNURBS takes each one as a separate, creating two parallel paper trails.
    Kind regards,
    Serge!Sokolov
    Sergei Sokolov replied 16 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
