Activity Forums Maxon Cinema 4D Tracer Question
  • Tracer Question
    Posted by Eddy Rose on July 18, 2011 at 10:08 pm
    So I want to model a tentacle and have it travel along a spline path. I’m pretty sure I can do this with the mograph tracer, I just somebody to point me in the right direction. How do I get the tentacle on the path?
    Greg Burrus replied 15 years, 2 months ago 3 Members · 2 Replies
  • Devaughn Williams
    July 18, 2011 at 10:41 pm
    Hey Im not 100% on this but you can try Align to spline under tags- Cinema 4D tags
  • Greg Burrus
    July 19, 2011 at 3:12 pm
    I can think of three way to do this and I’m sure there are more.
    The easiest I can think of is to use the cs tool which has a 3d stroke path already setup to do pretty much what you have in mind I think.
    https://circlesofdelusion.blogspot.com/.
    You could use this tentacle pack, https://dagpx.deviantart.com/gallery/#/d3gsums, that use’s tracer object with particles. I have used this my self in a little animation, https://vimeo.com/25383661
    Another idea would be to use what you have modeled and use the spline wrap to control it on the spline. You just need enough divisions in your model for it to bend correctly.
    Hope this help,
    Greg
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
