Activity › Forums › Adobe After Effects › tracer bullet moving away
Posted by Lisa Simonson on September 8, 2011 at 12:21 amHi,
I’m trying to create simple tracer bullets disappearing into the background. As if they were moving away from you (POV) I found tracer bullet tutorials but none from that angle. can someone help?
Lisa Simonson replied 15 years ago 3 Members · 5 Replies -
Corlin Palmer
September 8, 2011 at 12:42 amI would say just change the opacity of the tracer over time, so it will gently fade away
Michael Szalapski
September 8, 2011 at 5:14 pmWhat tutorial were you following that couldn’t be adapted to a different angle? If you’re using CC Particle World or Particular, it’s really easy. If you’re using Beam…well, it’s also really easy.
Basically I’m asking: how are you creating these tracers?
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Lisa Simonson
September 8, 2011 at 8:03 pmhi,
Thanks for responding! I found it not too difficult creating a side view or even 3/4 view tracer. Not sure though how one looks as its moving away from you, straight on. Is it like a dot that gets smaller? i would like it to show some arch near the end as it fades into the distance.
I made a few tracers. One in photoshop and one using a solid with added glow. No problem arching them across screen.
Maybe I should try particle world. Will check that out, thanks!
Michael Szalapski
September 8, 2011 at 8:45 pmIn real life a tracer is never actually shooting directly away from you. The gun is not at your eye level plus gravity and the angle at which you are firing all make a difference.
I know you’re trying CC Particle World, I’d also suggest trying the Beam effect.
– The Great Szalam
Lisa Simonson
September 8, 2011 at 8:50 pmThanks. I’m just now trying beam and its working out great!
