Activity Forums Maxon Cinema 4D TP – Matching Particle rotation to surface position normals
  • TP – Matching Particle rotation to surface position normals
    Posted by Will Macneil on September 8, 2005 at 1:39 pm
    I’m using a deformed plane as a surface position for my pyrocluster particles. I want the particles to stay aligned to the corresponding normals on the surface.
    Any ideas on how to do this?
    Will
    Will Macneil replied 21 years ago 2 Members · 2 Replies
  • Chris Smith
    September 8, 2005 at 2:28 pm
    If you’re using a PSurfacePosition node to attach the particles to a surface, pipe the ‘alignment’ out into the ‘alignment’ input of a PsetData node. Obviously pipe the particle stream in there as well.
    But the objext axis of what you are attaching needs to be oriented correctly for the object to stick out in the right position. You may want to prcatice with a cone to get the axis right first.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Will Macneil
    September 8, 2005 at 5:36 pm
    Thanks Chris,
    I’ll give it a go.
    W
