Activity Forums Maxon Cinema 4D TP limits using Pblurb
  • TP limits using Pblurb
    Posted by Joseph Bird on June 30, 2009 at 12:24 am
    I’m trying to use tp to assemble a piece of architectire as a particle system, and can get the effect to work on very low poly geometry. Is there a magic poly number that makes this work, i’m freezing up here. Is there a setting in preference that’ll make this possible, firmware upgrade?
    ATI Radeon HD 2600, 12 gigs ram on 8 core Mac…
    thanks!
    Adam Trachtenberg replied 17 years, 2 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 30, 2009 at 1:07 pm
    AFAIK there’s no set limit for number of particles. Are you sure you’re using the 64 bit version of Cinema so you can address all your ram?
