Activity Forums Maxon Cinema 4D TP issues (Frames in which groups change result in unexpected render results)
  • TP issues (Frames in which groups change result in unexpected render results)
    Posted by Dean Chapman on February 2, 2013 at 12:17 am
    I’m running into this issue frequently when using TP…..pretty sure it’s just human error (me being the human).
    I use an emitter to shoot (Group A) particles that hit a deflector (set to event only), which change them to (Group B). Group B hits another deflector, and that changes them to group C…and so on.
    My problem is at the frames where particles switch groups…..theres is always a static frame of a single particle…or a group of particles. I’ve attached 2 movie examples of what I’m talking about. Both are using mograph cache tags…but I encounter the same issue frequently without cache tags.
    The second movie (not the cross-section with the pink spheres) is set up with emitters shooting particles towards geometry using the PPosition Follow & PVolumePosition nodes……Same thing happens with static single spheres revealing at the frames in which the change in groups occurs.
    Any help with this would be really really great.
    https://reels.creativecow.net/film/tp-problem-vid-1
    https://reels.creativecow.net/film/tp-problem-vid-2
    dean
    Dean Chapman replied 13 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
