Activity Forums Maxon Cinema 4D TP collide and stick to moving collider
  • TP collide and stick to moving collider
    Posted by Corrado Carlevaro on January 18, 2017 at 11:19 am
    I want some particles to stick to a moving object when they collide with it
    (there’s a thread here with the same title but in the solution provided the particles are just bouncing back).
    I’m trying to use some presets in this way: a TP Standard Emitter, a TP Object Collision, a TP Group Change and then I guess I should use a PPosition Follow node like in the TP Sticky Goo preset to make the particles stick to the Collider but I don’t know how to put this last part together.
    Any help would be very appreciated.
    Thank you
    C.
    Corrado Carlevaro replied 9 years, 7 months ago 1 Member · 1 Reply
  • Corrado Carlevaro
    January 18, 2017 at 3:28 pm
    I just begun from scratch, without presets, and I found the PMotion Inheritance which solved the problem.
    Thank you
