Activity Forums Adobe After Effects Expressions .toWorld(anchorPoint) in PositionZ is displaced
  • .toWorld(anchorPoint) in PositionZ is displaced
    Posted by Vera Steinbeck on April 1, 2019 at 5:49 pm
    hey there!
    i have a problem with the generate-beam function.. i have the beam building a line and at the front of it i need a light following as emitter for particular.
    now everything worked fine in 2D, but in 3D, the Z-axis is off and i can’t find out why :/
    my expression simple: i have a linear expression on the light-position that moves from circleA to circleB along with the “time” setting from the beam-layer.
    if i stay in the same z-Axis the light follows without a problem. it i have a longer travel from about z0 to z300 then the light is delayed..
    does somebody have a clue, why this is happening?
    help would be greatly appreciated!
    13234_beamproblem.aep.zip
    Time = thisComp.layer(Beam).effect("Rope - Controls")("time");
    BeginningLayer = thisComp.layer("1").effect("Rope - Start")("Ebene").toWorld(anchorPoint)
    EndLayer = thisComp.layer("2").effect("Rope - End")("Ebene").toWorld(anchorPoint)
    linear(Time,0,50,BeginningLayer,EndLayer);
    //There may be typos in the code - i simplified it
    Vera Steinbeck replied 7 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 1, 2019 at 6:18 pm
    Is the Beam effect on a 2D layer? If so, try using toComp() instead of toWorld().
    Dan
  • Vera Steinbeck
    April 1, 2019 at 9:34 pm
    hi dan!
    thank you for your time! ????
    yes, the beam effect is on a 2D layer.. i tried using toComp(anchorPoint) but then the positionZ was way back in zPosition, about 1500
    hmm…
