Activity Forums Adobe After Effects Expressions toWorld Speed value?
  • toWorld Speed value?
    Posted by Gage Ullman on June 22, 2010 at 10:24 pm
    I’m trying to return the speed of an layer that is parented to another layer. That is, the speed of the child layer relative to the world. I can’t figure the syntax out. I would have assumed something like this:
    thisLayer.toWorld(thisLayer.position.speed)
    I keep getting an error that says “First argument to toWorld must be a vector of length 2 or 3.”
    um… so yeah. Any thoughts?
    Also, I guess I should say what I’m trying to do, incase there’s just a better way to do it. I’ve got a branch, it’s sort of blowing up and down in the wind (rotationally), and I have a couple leaves attached to it. And I want the leaves closer to the end of the branch to rotate farther than the ones closer to the base of it whenever the branch moves. So I figured the relative toWorld speed would be the best value to use to augment the rotation.
    Any thoughts?
    Dan Ebberts
    replied 16 years, 3 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    June 23, 2010 at 12:26 am
    .speed only works with properties (like position), not with arrays like those created by the layer space transforms. This should get you close:
    p1 = toWorld(anchorPoint);
    p0 = toWorld(anchorPoint,time-.01);
    spd = length(p1,p0)*100
    Dan
  • Gage Ullman
    June 23, 2010 at 12:31 am
    thank you so much. The last part of that… the *100 part… where does that number come from? Is it because we’re looking at the difference of position over on hundredth of a second? Actually, just needed to say that out loud to myself. Thank you!
  • Dan Ebberts
    June 23, 2010 at 12:34 am
    Sometimes it helps to talk it out. 🙂
    Dan
