Activity Forums Adobe After Effects Expressions toWorld / fromWorld functions in ExtendScript?
  • toWorld / fromWorld functions in ExtendScript?
    Posted by Martin Bollerup on February 25, 2013 at 10:14 pm
    Hello,
    I’m fooling around with parented solids and need their world coordinates – is there a simple way like the toWorld expression function? I can’t seem to make it work using only scripting…
    Martin
    Dan Ebberts replied 9 years, 6 months ago 3 Members · 4 Replies
  • Dan Ebberts
    February 25, 2013 at 10:26 pm
    I would have the script add a 3D Point Control (CS5.5 or later), apply the toWorld() expression, harvest the results, and delete the control.
    Dan
  • Rob Mcgowan
    February 27, 2017 at 7:52 pm
    Is there any way to do this in CS4?
  • Dan Ebberts
    February 27, 2017 at 8:02 pm
    I guess you could use three sliders, each publishing one dimension of the 3D result.
    Dan
  • Dan Ebberts
    February 27, 2017 at 8:43 pm
    Or probably better, just apply 3 different expressions (one for each dimension) to a single slider (harvesting the result each time);
    Dan
