Activity Forums DVD Authoring tough project issue
  • tough project issue
    Posted by Jonovo on November 16, 2006 at 5:56 pm
    hi there,
    i have to do a dvd.project with the following concept and need some help…
    sounds easy, like a multiangle structure, but with one difficult issue:
    there are 13 versions of a movie. one of them is showing in the
    main-screen, that should work as a kind of graphic-menu/interface, too.
    by selecting the buttons in the mainscreen (where the main-movie is
    running) you should be able to switch to each one of the 12 other versions seamlessly.
    BUT: like an other angle-view in a multiangle-dvd it should not start at the beginning of the movies, but using one absolute time for all the different versions.
    for example: you are at 5’41” in the main movie and push the menu-button #6, so it should switch seamless to movie #6 at 5’41” …
    it should be some kind of a multiangle-like structure but with graphical buttons to select the different views, instead of simply switching through the angle-views by using the angle-button on the remote control …
    any suggestions?
    what software should i use?
    thanks a lot!!!
    jonovo
    Roman Melekh replied 19 years, 9 months ago 3 Members · 2 Replies
  • Eric Pautsch
    November 16, 2006 at 7:44 pm
    This would be a button over video situation but changing angles with buttons over video would be difficult if not impossible. I believe I’ve heard of a company up in San Fransisco that may have done something like this.
    Besides…you would need a Scenarist or the Panasonic authoring system to accomplish this
  • Roman Melekh
    November 17, 2006 at 7:40 am
    You must use Sonic Scenarist software. And create multi-angle video-track.
    But – only 8 angles can be in track…
