Activity › Forums › Adobe After Effects › Touching Twitch Makes After Effects Not Respond
  • Touching Twitch Makes After Effects Not Respond
    Posted by Eric Tong on March 11, 2015 at 1:14 am
    Every time I do something to the twitch plugin (add to comp, change value, edit length of layer with twitch) after effects stops responding for a really long time (5 min). This doesn’t happen with any other plugins. I tried reinstalling twitch 3 times already. Anyone else had this problem?
    Eric Tong replied 11 years, 6 months ago 2 Members · 2 Replies
  • Daniel Waldron
    March 11, 2015 at 4:04 pm
    Never had that issue. Did it used to work normally for you? If so, the issue can usually be tracked back to a change in your system or software.
    You could also email VideoCopilot. They’re usually pretty responsive.
  • Eric Tong
    March 11, 2015 at 9:48 pm
    Good point, I never did have that issue before. Thanks, I’ll try emailing Video Copilot, but I don’t really know how to trace this problem…
