Activity Forums Blackmagic Design TouchDirector App ATEM control
  • TouchDirector App ATEM control
    Posted by Saskia-anett Ebelt on November 18, 2019 at 11:33 pm
    Our TouchDirector iPad app is released now!
    It’s an feature-rich iPad App to control ATEM switcher. We developed it since 2 years and tested the app in many live productions with different ATEM’s.
    ATEM switcher control with much more advantages like SuperSource saving and recall.
    PGM /PVW row is every time visible and switchable, you can also swap PGM/PVW row to switch more comfortably on the iPad.
    The most needed Keys and Transitions can be activated direkt in the Transition area.
    See the audio levels live and adjust them while switching along.
    All aux sources viewable on one view and set them.
    Stills and clips can be chosen from the ATEM integrated Media-Player, tie clips with DSK or Transition.
    Switch SuperSource Boxes live, save and recall as much of them if you like (only 2M/E and 4M/E ATEM).
    One or two HyperDecks/HyperDecks Mini connectable and as fully automated integrated Mediaplayer usable for pre-produced clips or key-animations.
    (use fill and key output at the HyperDeck Mini for alpha channel clips).
    Play back your key animations tied with DSK 1 and 2 or chained up with a Transition (only with HyperDeck Mini in ProRes 4444 with Alpha).
    Generate Cliplists and, mark in and out and set repeat for your clips stored on your HyperDeck and HyperDeck Mini
    Assign HyperDeck inputs related to their physical inputs in the Deck Assignments, also for Key and Fill.
    All Key and DSK channels on one view in the Key Assignment settings.
    The app works with ATEM software 8.0 and also higher.
    The app works with all ATEM. (except the Constellation 8k and the TVS 4K Pro, this will come in December 2019)
    Introductory price until end of November 2019 around 30,- US$in the Apple AppStore
    https://liveskills.net/touchdirector/
    https://apps.apple.com/de/app/touchdire … 1450852852
    https://liveskills.net/downloads/TD-Qui … ide-QR.png
    How to export clips for HyperDeck playback:
    https://liveskills.net/downloads/TD-HD- … Manual.pdf
    Best regards, Anett from LiveSkills
    Saskia-Anett Ebelt, vision mixer on BM Atem, Tricaster 460 and TC1, Panasonic, NewBlueFX Live Titler, Teradek, Matrox, Developer of Liveskills Apps HyperSlow to control BM HyperDecks as an instant replay system, and HyperSynchron to control and supervise up to 16 HyperDecks
    Saskia-anett Ebelt replied 3 years, 6 months ago 1 Member · 2 Replies
  • Saskia-anett Ebelt
    December 1, 2019 at 12:48 am
    ATEM and HyperDeck iPAD Apps 20% off Deal
    until 03.12.2019!
    TouchDirector, introduction 30,-USD until 03.12.2019
    HyperSlow 3.0, 40,-USD until 03.12.2019
    https://apps.apple.com/de/app/hyperslow/id1147161413
    https://liveskills.net/hyperslow/
    HyperSynchron, 15,- USD until 03.12.2019
    https://apps.apple.com/de/app/hypersync … 1242530106
    https://liveskills.net/hypersynchron/
    Best regards, LiveSkills
    Download HyperSynchron One for free to control a single HyperDeck.
    https://apps.apple.com/de/app/hypersync … 1439652093
    January 23, 2023 at 12:49 am
    TouchDirector ATEM panel app release 5.02
    TouchDirector Mini ATEM panel app release 5.0
    New: Macro driven animation of SuperSource boxes and also up to 4 DVE key boxes with realtime generated macros. TouchDirector is generating, sending and executing animation macros in realtime.
    This revolutionary solution makes animation much smoother, for SuperSource animation in progressive formats.
    For DVE Key animation in high quality in all progressive and interlaced formats (Mini only progressive Formats).
    With built in easing and ramp for run in and run out for all animations with automatic calculation for the video project framerate.
    User are now able to create complexe DVE Key (DVEK) animations with up to 4 PIP boxes in one composition and to use it in the same manner as SuperSource compositions.
    (number of DVEK PIP boxes depends on ATEM type)
    TouchDirector combines up to 4 single DVE Key PIP boxes to one composition, which can be saved, animated and assigned to quick buttons like a SuperSource composition (4 Boxes by ATEM Constellation, 2 Boxes by ATEM Mini Extreme).
    SuperSource wasn’t intended for animation by Blackmagic Design, but DVE Key PIP was. With the new LiveSkills macro driven DVEK animation the user can generate PIP animation in high quality.
    Network connection isn’t more so critical compared to other SuperSource animation solutions, which doesn’t create macros like TouchDirector and instead of macro generating firing many commands to the ATEM to move the PIP boxes.
    Use of animated Multi PIP compositions in high quality or broadcast environment is now much easier with TouchDirector DVEK compositions.
    New: Select sources for all aux out in a broadcast panel design with customizable buttons.
    New: Select sources for all upstream keys and all DSK keys in a broadcast panel design with customizable buttons.
    New: Control up to 4 ATEM integrated Media Player (up to 4 by Constellation 8K)
    In addition to PVW/PGM and transition/key area, you can select one of the following sections:
    • Audio
    • HyperDeck playback control
    • Aux source control
    • Key source control
    • ATEM internal media player
    • SuperSource control and animation /DVEK control and animation
    • Worldwide Tally system over internet server (free WorldTally client app for clients)
    • streaming/recording (ATEM Mini’s), timecode (all ATEM)
    • all macros (available in macro section and as quick macro buttons in PVW/PGM section)
    TouchDirector ATEM panel App for iPad for all ATEM switcher.
    Available in the Apple App Store.
    https://apps.apple.com/de/app/id1450852852
    https://apps.apple.com/de/app/id1501018263
    28 days free test code via Apple TestFlight, full current app version!
    https://testflight.apple.com/join/RcvAqWtS
    https://testflight.apple.com/join/VPnLGtdj
    TouchDirector (Mini) App works with ATEM software 8.9 and higher.
    App works with all iPads from iOS 14.
    The TouchDirector App works with all ATEM switchers models from 2015, as also now with older models, as far they have installed ATEM software 8.6.x.
    The TouchDirector Mini App works with all ATEM Mini switchers.
    We recommend urgent to test the app from the test code above.
    The price for the TouchDirector full app for iPad is approx. $50,
    Prices depending on local taxes in your country.
    The price for the TouchDirector Mini app for iPad is approx. $35,
    Combine TouchDirector App with other free LiveSkills-Apps to
    get worldwide Tally or ATEM worldwide remote control.
    TouchDirector Remote for ATEM
    WorldTally client
    Use your iPad as ATEM panel with TouchDirector.
    We recommend to use the Blackmagic Design ATEM software in addition to adjust special setups for e.g. key or stinger.
    Best regards to all, the LiveSkills Team
