Activity › Forums › Adobe After Effects Expressions › Tote Board Effect
  • Posted by Scott Moore on August 28, 2009 at 12:28 am
    I need to make a Tote Board for the MDA Telethon.
    I have everything I need but I am trying to simplify my work a little.
    Ok So I have a starting number say $15,875.
    And a ending number say $17,874.
    I like the numbers, and just the numbers randomize and slowly reveal the numbers by starting with the lowest digit.
    The numbers can range from $1 to $999,999. I like the $ dollar sign and the comma to stay the same.
    Any suggestions?
    Dan Ebberts
    replied 17 years, 1 month ago
    2 Members · 2 Replies
  • Scott Moore
    August 28, 2009 at 8:42 am
    Update:
    I got the numbers to do what I want.
    I created a slider controller and using an expression to have the text change the same time I’m doing a animation with the Character Offset and Range Selector. This works great and does what I want to do.
    I have one little issue I like to clean up and make easier.
    I am using this expression on my main text layer;
    s = “158 990,255 789”;
    j = (thisComp.layer(“Text Controller”).effect(“Tote Control”)(“Slider”)*1);
    s.split (“,”) [j];
    on the 1st line I like to point the text to another source. For example:
    s = thisComp.layer(“158 238”).text.sourceText,thisComp.layer(“255 789”).text.sourceText;
    When I do this line 3 does not work.
    Any suggestions on how to fix this expression?
    Thanks.
  • Dan Ebberts
    August 28, 2009 at 1:56 pm
    I would guess it’s going to look like this:
    s = [thisComp.layer(“158 238”).text.sourceText,thisComp.layer(“255 789”).text.sourceText];
    s[j];
    (not tested though)
    Dan
