Activity › Forums › VEGAS Pro › Totally remove motion blur?
  • Totally remove motion blur?
    Posted by Alex Wilson on May 3, 2009 at 5:16 pm
    Whenever I render a video, I still see motion blur even after I bypass all effects and set the motion blur to zero. How do I completely remove it?
    Thanks in advance.
    John Rofrano replied 17 years, 4 months ago 3 Members · 3 Replies
  • John Rofrano
    May 3, 2009 at 5:26 pm
    I assume there is no motion blur in the original video? If there is, there is no way to remove it.
    Did you change the frame rate of the render from that of the source video files? If so, you can switch on Disable Resample on all of the events to stop Vegas from interpolating the frame rate difference.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Serge Tremblay
    May 9, 2009 at 4:57 pm
    I had the exact same problem. After verifying, my source video (3d generated video) had a 30.000 framerate and the output was 29.970. Disabling the resample worked perfectly.
    Thank you for the solution!
    Serge
  • John Rofrano
    May 9, 2009 at 8:25 pm
    You’re welcome. Glad that was it.
    ~jr
