Activity › Forums › Apple Final Cut Pro › Total FCPX Project Duration — Difference between FCPX and QT movie
  • Total FCPX Project Duration — Difference between FCPX and QT movie
    Posted by Bill Rabkin on July 14, 2016 at 5:48 pm
    I created an HD FCPX project in which the timeline is exactly 1:16:40 long. I share (export) a QuickTime movie using the H.264 codec. The resulting QT .mov is 1:16:44 long.
    A colleague and I have both found this to happen with several of our FCPX projects — the movie is always a few seconds longer than the project storyline in FCPX.
    We would appreciate any thoughts about what causes this discrepancy, and any workarounds.
    Paul Neumann replied 10 years, 2 months ago 4 Members · 3 Replies
  • Jeremy Garchow
    July 15, 2016 at 3:56 pm
    Drop vs non-drop frame?
  • Doug Metz
    July 15, 2016 at 4:45 pm
    [Jeremy Garchow] “Drop vs non-drop frame?”
    That was my first thought, too.
    One way to check this:
    – open your project in FCP, change the ‘Time Display’ preference (under General tab) to Frames
    – check the bottom center of the interface to get a total frame count
    – open your exported file in QT7, and click on the time display in the lower left corner – change to Frame Number
    If those two numbers match, it’s a timecode issue. If they don’t…. well… that’s another kettle of fish!
    Doug Metz
    Anode
  • Paul Neumann
    July 16, 2016 at 4:44 am
    1:16:40:00 of drop frame is 1:16:44:06 of non-drop.
